Saltar al contenido principal
Inter-tel IP 8660 Internal speaker Replacement
Qué necesitas
  1. Inter-tel IP 8660 Internal speaker Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Internal speaker Replacement: paso 2, imagen 1 de 3 Inter-tel IP 8660 Internal speaker Replacement: paso 2, imagen 2 de 3 Inter-tel IP 8660 Internal speaker Replacement: paso 2, imagen 3 de 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Internal speaker Replacement: paso 3, imagen 1 de 1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Internal speaker Replacement, Internal speaker: paso 4, imagen 1 de 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Internal speaker Replacement: paso 5, imagen 1 de 1
    • Lift up the speaker.
Conclusión
Megan Buck
Miembro Desde 01/20/12
15 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-24, Maness Winter 2012 Miembro de Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 789
