Introducción
This guide details the steps to take off the button pad of your Inter-tel IP 8660.
Partes
No se requieren partes.
  1. Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
      • 8 mm long
      • 11 mm long
    • Lift up the back cover and set it aside.
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
    • Lift up the speaker.
    • Lift up the motherboard and set aside
    • Peel off all rubber button covers.
    • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 11-24, Maness Winter 2012 Miembro de Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 675
