Saltar al contenido principal
Instant Pot Smart-60 Plastic Base Replacement
Qué necesitas
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: paso 1, imagen 1 de 2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: paso 1, imagen 2 de 2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: paso 2, imagen 1 de 1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: paso 3, imagen 1 de 1
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: paso 4, imagen 1 de 1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: paso 5, imagen 1 de 1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
Conclusión
3 personas más completaron esta guía.
paola alvarez
Miembro Desde 01/24/18
534 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S1-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Miembros
6 Guías creadas
13 comentarios
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - Contestar
Hello where can I buy the plastic base
Maureen - Contestar
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - Contestar
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - Contestar
Do you carry the replacement for this. Thanks
khai01 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 6,658
