Introducción
The LED display is how you communicate with your Instant Pot. This guide will show you how to remove the display from the front of your device.
Qué necesitas
Open the lid by turning it counter-clockwise and lifting up.
Remove the inner pot.
Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
Pull up on the cn101 connection to detach the LED display from the motherboard.
6 personas más completaron esta guía.
2 comentarios
Where can I get the replacement for the display?
