Saltar al contenido principal
Installing a Petsafe Removable Dog Panel
Qué necesitas
  1. Installing a Petsafe Removable Dog Panel, Petsafe Dog Panel: paso 1, imagen 1 de 1
    • Make sure you have all the tools necessary.
  2. Installing a Petsafe Removable Dog Panel: paso 2, imagen 1 de 1
    • Receive your PetSafe dog door in the mail.
  3. Installing a Petsafe Removable Dog Panel: paso 3, imagen 1 de 2 Installing a Petsafe Removable Dog Panel: paso 3, imagen 2 de 2
    • Measure the height of the sliding glass door frame.
  4. Installing a Petsafe Removable Dog Panel: paso 4, imagen 1 de 3 Installing a Petsafe Removable Dog Panel: paso 4, imagen 2 de 3 Installing a Petsafe Removable Dog Panel: paso 4, imagen 3 de 3
    • Remove your lock latch from the sliding door frame.
    • Lock latches may vary
  5. Installing a Petsafe Removable Dog Panel: paso 5, imagen 1 de 2 Installing a Petsafe Removable Dog Panel: paso 5, imagen 2 de 2
    • Slide the top of your dog panel into the top track of the sliding glass door.
    • Place the bottom portion of the dog panel into the bottom track of the sliding glass door.
  6. Installing a Petsafe Removable Dog Panel: paso 6, imagen 1 de 2 Installing a Petsafe Removable Dog Panel: paso 6, imagen 2 de 2
    • Measure 12” from the top, down the side of your sliding glass door frame and mark it.
    • Mark 1” above the pet flap onto the edge of your sliding glass door.
  7. Installing a Petsafe Removable Dog Panel: paso 7, imagen 1 de 3 Installing a Petsafe Removable Dog Panel: paso 7, imagen 2 de 3 Installing a Petsafe Removable Dog Panel: paso 7, imagen 3 de 3
    • With a 9/64ths drill bit, drill clearance holes into the marks made on the sliding glass door frame
    • DO NOT GO THROUGH THE DOG PANEL
  8. Installing a Petsafe Removable Dog Panel: paso 8, imagen 1 de 3 Installing a Petsafe Removable Dog Panel: paso 8, imagen 2 de 3 Installing a Petsafe Removable Dog Panel: paso 8, imagen 3 de 3
    • Fasten the panel to the interior side of the sliding glass frame with the provided ⅝” screws.
    • MAKE SURE YOU ARE DRILLING OUTSIDE OF THE RIBBED LINE ON THE DOG PANEL.
    • DO NOT OVERTIGHTEN.
  9. Installing a Petsafe Removable Dog Panel: paso 9, imagen 1 de 2 Installing a Petsafe Removable Dog Panel: paso 9, imagen 2 de 2
    • Tighten the screws with a screwdriver.
  10. Installing a Petsafe Removable Dog Panel: paso 10, imagen 1 de 3 Installing a Petsafe Removable Dog Panel: paso 10, imagen 2 de 3 Installing a Petsafe Removable Dog Panel: paso 10, imagen 3 de 3
    • Repeat steps 8 and 9 to secure the dog panel into place. Follow these steps when drilling into the clearance hole marked at the top of the frame.
  11. Installing a Petsafe Removable Dog Panel: paso 11, imagen 1 de 1
    • Slide your sliding door flush against the dog door.
Conclusión
Una persona más ha completado esta guía.
Joshua Novello
Miembro Desde 10/26/18
196 Reputación
1 Guía escrita
Equipo
UC Davis, Team S1-G1, Bender Fall 2018 Miembro de UC Davis, Team S1-G1, Bender Fall 2018
UCD-BENDER-F18S1G1
3 Miembros
1 Guía escrita
2 comentarios
My dog won’t push hard enough for the magnet to open. Is there a way to temporarily remove the magnet on either the frame or the flap?
LisaD - Contestar
LisaD put a piece of masking tape over the magnet or a couple of layers of tape to make it easier to open maybe?
Robert Merry -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 35
Todo El Tiempo: 1,095
