Saltar al contenido principal
Installing Sewing Machine Bobbin
Qué necesitas
  1. Installing Sewing Machine Bobbin, Bobbin: paso 1, imagen 1 de 2 Installing Sewing Machine Bobbin, Bobbin: paso 1, imagen 2 de 2
    • Use your finger to open the bobbin door below the presser foot.
  2. Installing Sewing Machine Bobbin: paso 2, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 2, imagen 2 de 2
    • Align the hole in the bobbin spindle over the peg in the bobbin case.
    • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
    • Take the loose thread end and slide it through the slit on the side of the bobbin case.
  3. Installing Sewing Machine Bobbin: paso 3, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 3, imagen 2 de 2
    • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
  4. Installing Sewing Machine Bobbin: paso 4, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 4, imagen 2 de 2
    • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
    • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
  5. Installing Sewing Machine Bobbin: paso 5, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 5, imagen 2 de 2
    • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
    • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
    • Release the bobbin case.
  6. Installing Sewing Machine Bobbin: paso 6, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 6, imagen 2 de 2
    • Close the door on the compartment below the presser foot.
Linea de Meta
5 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
89,011 Reputación
131 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,732 Guías creadas
Un comentario
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 18
Ultimos 7 días: 128
Ultimos 30 días: 596
Todo El Tiempo: 49,395
