Saltar al contenido principal
Installing Hook-and-Loop Tape in Clothing
Qué necesitas
  1. Installing Hook-and-Loop Tape in Clothing, Installing Hook-and-Loop Tape in Clothing: paso 1, imagen 1 de 2 Installing Hook-and-Loop Tape in Clothing, Installing Hook-and-Loop Tape in Clothing: paso 1, imagen 2 de 2
    • Lay your piece of hook-and-loop tape on the fabric where you would like it to live.
    • Pin the hook-and-loop tape into place.
  2. Installing Hook-and-Loop Tape in Clothing: paso 2, imagen 1 de 2 Installing Hook-and-Loop Tape in Clothing: paso 2, imagen 2 de 2
    • Position your fabric under the presser foot of your sewing machine in the upper right hand corner of the hook-and-loop tape. Drop the presser foot.
    • Use the balance wheel to sink the needle.
    • The balance wheel should only be turned in the direction that advances the sewing machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
  3. Installing Hook-and-Loop Tape in Clothing: paso 3, imagen 1 de 3 Installing Hook-and-Loop Tape in Clothing: paso 3, imagen 2 de 3 Installing Hook-and-Loop Tape in Clothing: paso 3, imagen 3 de 3
    • Sew along the edge of the hook-and-loop tape, stopping just at the end.
    • Pull the pin out.
    • When you pull the pin out, be sure the needle is already down. If not, use the balance wheel to sink the needle into the fabric.
  4. Installing Hook-and-Loop Tape in Clothing: paso 4, imagen 1 de 3 Installing Hook-and-Loop Tape in Clothing: paso 4, imagen 2 de 3 Installing Hook-and-Loop Tape in Clothing: paso 4, imagen 3 de 3
    • Lift the presser foot, leaving the needle sunk.
    • Rotate the fabric 90º counterclockwise.
  5. Installing Hook-and-Loop Tape in Clothing: paso 5, imagen 1 de 2 Installing Hook-and-Loop Tape in Clothing: paso 5, imagen 2 de 2
    • Lower the presser foot and sew the second side of the hook-and-loop tape.
    • Continue sewing the hook-and-loop tape. When you come to the end of a side, sink the needle into the fabric and lift the presser foot. Then turn the fabric at each of the remaining corners.
  6. Installing Hook-and-Loop Tape in Clothing: paso 6, imagen 1 de 2 Installing Hook-and-Loop Tape in Clothing: paso 6, imagen 2 de 2
    • On the last side of the hook-and-loop tape, backstitch over the last few stitches.
  7. Installing Hook-and-Loop Tape in Clothing: paso 7, imagen 1 de 3 Installing Hook-and-Loop Tape in Clothing: paso 7, imagen 2 de 3 Installing Hook-and-Loop Tape in Clothing: paso 7, imagen 3 de 3
    • Clip the threads, freeing the fabric from the sewing machine.
    • Clip the extra thread off.
    • Repeat this guide for the other side of the hook-and-loop tape.
Linea de Meta
Brittany McCrigler
Miembro Desde 03/05/12
89,011 Reputación
131 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,757 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 36
Ultimos 30 días: 206
Todo El Tiempo: 33,244
