Saltar al contenido principal
Install an Extension Cord Female Plug
Qué necesitas
  1. Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: paso 1, imagen 1 de 3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: paso 1, imagen 2 de 3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: paso 1, imagen 3 de 3
    • Install an Extension Cord Female Plug is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut from the middle and around the cable.
  2. Install an Extension Cord Female Plug: paso 2, imagen 1 de 3 Install an Extension Cord Female Plug: paso 2, imagen 2 de 3 Install an Extension Cord Female Plug: paso 2, imagen 3 de 3
    • Use wire strippers to remove about 2 cm from the inner wires
  3. Install an Extension Cord Female Plug: paso 3, imagen 1 de 2 Install an Extension Cord Female Plug: paso 3, imagen 2 de 2
    • Make sure you put the bottom cover of the female plug.
  4. Install an Extension Cord Female Plug: paso 4, imagen 1 de 3 Install an Extension Cord Female Plug: paso 4, imagen 2 de 3 Install an Extension Cord Female Plug: paso 4, imagen 3 de 3
    • The green screw is for the (green wire), the gold screw is for the (black wire), and the silver screw is for the (white wire).
    • For green wire.
    • For black wire
    • For white wire.
    • Now when you have each wire inside the hole you tighten the three screws.
  5. Install an Extension Cord Female Plug: paso 5, imagen 1 de 3 Install an Extension Cord Female Plug: paso 5, imagen 2 de 3 Install an Extension Cord Female Plug: paso 5, imagen 3 de 3
    • Electrical tape is optional.
    • Need to make sure both of the parts are lined up in the same directions.
    • Push both parts together and you would see the screws pop up.
  6. Install an Extension Cord Female Plug: paso 6, imagen 1 de 3 Install an Extension Cord Female Plug: paso 6, imagen 2 de 3 Install an Extension Cord Female Plug: paso 6, imagen 3 de 3
    • Tightening the top three screws.
    • Also, need to tighten the two bottom screws.
    • Make sure you have one or two fingers in the back of the two screws so they pop up.
  7. Install an Extension Cord Female Plug: paso 7, imagen 1 de 1
    • Test out.
Conclusión
2 personas más completaron esta guía.
Steven Quintero
Miembro Desde 10/23/23
172 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 56
Todo El Tiempo: 265
