Saltar al contenido principal
Inspiron 7359 2-in-1 Fan Replacement
Qué necesitas
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: paso 1, imagen 1 de 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: paso 2, imagen 1 de 2 Inspiron 7359 2-in-1 Fan Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: paso 3, imagen 1 de 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: paso 4, imagen 1 de 1
    • All hardware components should be exposed.
  5. Aviso: los pasos 5-6 provienen de una guía que está marcada como "En progreso".
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: paso 5, imagen 1 de 1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: paso 6, imagen 1 de 2 Inspiron 7359 2-in-1 Fan Replacement: paso 6, imagen 2 de 2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: paso 7, imagen 1 de 2 Inspiron 7359 2-in-1 Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: paso 8, imagen 1 de 1
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: paso 9, imagen 1 de 1
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Conclusión
Dominique
Miembro Desde 08/26/19
251 Reputación
2 Guías creadas
Equipo
Gateway, Team S1-G3, Saknee Fall 2019 Miembro de Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 448
