Saltar al contenido principal
Insignia Sport NS-4V17 Scroll Wheel Replacement
Qué necesitas
  1. Insignia Sport NS-4V17 Scroll Wheel Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 2, imagen 1 de 2 Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 2, imagen 2 de 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 3, imagen 1 de 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 4, imagen 1 de 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Scroll Wheel Replacement, Front Case Cover: paso 5, imagen 1 de 2 Insignia Sport NS-4V17 Scroll Wheel Replacement, Front Case Cover: paso 5, imagen 2 de 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 6, imagen 1 de 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 7, imagen 1 de 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 7, imagen 2 de 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 7, imagen 3 de 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 8, imagen 1 de 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Scroll Wheel Replacement, Scroll Wheel: paso 9, imagen 1 de 1
    • Remove the white plastic ring from around the scroll wheel using your fingers.
  10. Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 10, imagen 1 de 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 10, imagen 2 de 3 Insignia Sport NS-4V17 Scroll Wheel Replacement: paso 10, imagen 3 de 3
    • Insert the plastic opening tool underneath any side of the scroll wheel.
    • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
Conclusión
Wesley Ballar
Miembro Desde 04/18/13
88 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 12-36, Amido Spring 2013 Miembro de Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 456
