Introducción
Unresponsive Play/Pause Button? Need to switch it out? This guide will show you how to remove the Play/Pause Button. This guide has a few tricky parts, but if you follow along you should have it off in no time.
Qué necesitas
Remove the four corner plastic covers on the back of the device using the plastic opening tool.
Remove the white plastic ring from around the scroll wheel using your fingers.
Slightly insert plastic opening tool underneath any side of the play button.
