Saltar al contenido principal
Insignia Sport NS-4V17 Battery Replacement
Qué necesitas
  1. Insignia Sport NS-4V17 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Battery Replacement: paso 2, imagen 1 de 2 Insignia Sport NS-4V17 Battery Replacement: paso 2, imagen 2 de 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Battery Replacement: paso 3, imagen 1 de 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Battery Replacement: paso 4, imagen 1 de 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 12-36, Amido Spring 2013 Miembro de Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,114
