Saltar al contenido principal
Insignia NS-VCS14SL7 Power Button Replacement
Qué necesitas
  1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: paso 1, imagen 1 de 2 Insignia NS-VCS14SL7 Power Button Replacement, Battery: paso 1, imagen 2 de 2
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Insignia NS-VCS14SL7 Power Button Replacement: paso 2, imagen 1 de 3 Insignia NS-VCS14SL7 Power Button Replacement: paso 2, imagen 2 de 3 Insignia NS-VCS14SL7 Power Button Replacement: paso 2, imagen 3 de 3
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Insignia NS-VCS14SL7 Power Button Replacement: paso 3, imagen 1 de 2 Insignia NS-VCS14SL7 Power Button Replacement: paso 3, imagen 2 de 2
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Insignia NS-VCS14SL7 Power Button Replacement: paso 4, imagen 1 de 1
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
  5. Insignia NS-VCS14SL7 Power Button Replacement, Handheld Vacuum Power Button: paso 5, imagen 1 de 1
    • Remove motor and impeller housing to gain access to power button.
  6. Insignia NS-VCS14SL7 Power Button Replacement: paso 6, imagen 1 de 2 Insignia NS-VCS14SL7 Power Button Replacement: paso 6, imagen 2 de 2
    • Pry upwards on the retaining clip with black plastic spudger and pull to remove the 5 pin connector.
  7. Insignia NS-VCS14SL7 Power Button Replacement: paso 7, imagen 1 de 2 Insignia NS-VCS14SL7 Power Button Replacement: paso 7, imagen 2 de 2
    • Remove the two 10mm Philips #2 screws holding the brown printed circuit board to the vacuum.
    • Remove brown printed circuit board.
    • Pull up on clear plastic power button assembly to remove.
Conclusión
Thibaut Pillot
Miembro Desde 02/15/18
434 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S16-G3, Boczar Spring 2018 Miembro de USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 215
