Saltar al contenido principal
Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement
Qué necesitas
  1. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the rubber sleeve.
  2. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 2, imagen 1 de 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 2, imagen 2 de 2
    • Use the specified screwdriver to unscrew the ten screws on the back cover.
  3. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 3, imagen 1 de 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 3, imagen 2 de 2
    • Remove the back cover. Be careful to not lose any of the screws because they are extremely small and can be easily lost.
  4. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 4, imagen 1 de 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 4, imagen 2 de 2
    • The battery will be attached to the back cover with sticky tape. Unplug the wires connecting the battery to the speaker.
    • Using one of the four blue opening tools, pry the battery off of the back cover.
  5. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 6, imagen 1 de 1
    • Stick the new battery to the back cover using sticky tape.
  6. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 7, imagen 1 de 1
    • Connect the wire from the new battery to the bluetooth speaker.
  7. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 8, imagen 1 de 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 8, imagen 2 de 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: paso 8, imagen 3 de 3
    • Place cover back on and using the iFixit screwdriver PH000, screw the ten screws back onto the back cover.
Conclusión
Erin Steele
Miembro Desde 03/08/17
649 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 295
