Saltar al contenido principal
Insignia NS-SPBTBRICK Battery Replacement
Qué necesitas
  1. Insignia NS-SPBTBRICK Battery Replacement, Battery: paso 1, imagen 1 de 2 Insignia NS-SPBTBRICK Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case.
  2. Insignia NS-SPBTBRICK Battery Replacement: paso 2, imagen 1 de 2 Insignia NS-SPBTBRICK Battery Replacement: paso 2, imagen 2 de 2
    • Turn the device around and gently push the speaker through until it separates from the sleeve.
  3. Insignia NS-SPBTBRICK Battery Replacement: paso 3, imagen 1 de 2 Insignia NS-SPBTBRICK Battery Replacement: paso 3, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit.
  4. Insignia NS-SPBTBRICK Battery Replacement: paso 4, imagen 1 de 3 Insignia NS-SPBTBRICK Battery Replacement: paso 4, imagen 2 de 3 Insignia NS-SPBTBRICK Battery Replacement: paso 4, imagen 3 de 3
    • Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel.
  5. Insignia NS-SPBTBRICK Battery Replacement: paso 5, imagen 1 de 2 Insignia NS-SPBTBRICK Battery Replacement: paso 5, imagen 2 de 2
    • Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery.
Conclusión
After detaching, you can replace with a new panel and battery, or detach the battery from the panel adhesive and replace the battery on the existing panel. To reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
Austin Gratzer
Miembro Desde 03/26/18
127 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G6, Harley Spring 2018 Miembro de IUPUI, Team S2-G6, Harley Spring 2018
IUPUI-HARLEY-S18S2G6
3 Miembros
2 Guías creadas
Un comentario
Where can I get a new battery for my Speaker?
David Villa - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 974
