Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will show you how to remove the back cover and replace the battery in the radio. There will be several small screws and rubber covers so make sure you have a container to keep them in so that they are not lost.
  1. Remove the rubber screw caps using the pointed tip of the Spudger.
    • Remove the rubber screw caps using the pointed tip of the Spudger.
  2. Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
    • Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
  3. Use the plastic opening tool to pry open the back cover. Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
    • Use the plastic opening tool to pry open the back cover.
    • Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
  4. Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides. Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides. Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
    • Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
  5. Use the flat side of the Spudger to pry the battery out of the back cover. Insert the replacement battery into the back cover.
    • Use the flat side of the Spudger to pry the battery out of the back cover.
    • Insert the replacement battery into the back cover.
    • Reassemble the radio, making sure to reconnect the battery cable.
Conclusión
2 personas más completaron esta guía.
Joel Najmon
Miembro Desde 08/10/16
152 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-2, Wilson Fall 2016 Miembro de IUPUI, Team 2-2, Wilson Fall 2016
IUPUI-WILSON-F16S2G2
5 Miembros
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 542
