Saltar al contenido principal
Insignia NS-F12R6-SS Motor Housing Replacing
Qué necesitas
  1. Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: paso 1, imagen 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: paso 1, imagen 2 de 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Motor Housing Replacing: paso 2, imagen 1 de 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Motor Housing Replacing: paso 3, imagen 1 de 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Motor Housing Replacing, Fan Blade: paso 4, imagen 1 de 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Motor Housing Replacing: paso 5, imagen 1 de 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Motor Housing Replacing, Back Cage: paso 6, imagen 1 de 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Motor Housing Replacing: paso 7, imagen 1 de 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: paso 8, imagen 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: paso 8, imagen 2 de 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Motor Housing Replacing: paso 9, imagen 1 de 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Motor Housing Replacing, Motor Housing: paso 10, imagen 1 de 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Motor Housing Replacing: paso 11, imagen 1 de 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Motor Housing Replacing: paso 12, imagen 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing: paso 12, imagen 2 de 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Motor Housing Replacing: paso 13, imagen 1 de 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Motor Housing Replacing: paso 14, imagen 1 de 2 Insignia NS-F12R6-SS Motor Housing Replacing: paso 14, imagen 2 de 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Motor Housing Replacing: paso 15, imagen 1 de 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Motor Housing Replacing: paso 16, imagen 1 de 1
    • Remove the small piece of paper hanging on the power button.
Conclusión
3 personas más completaron esta guía.
Hank
Miembro Desde 09/17/18
1,142 Reputación
8 Guías creadas
Equipo
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,586
