Saltar al contenido principal
Insignia NS-CLOPP2 Screen Replacement
Qué necesitas
  1. Insignia NS-CLOPP2 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
  2. Insignia NS-CLOPP2 Screen Replacement: paso 2, imagen 1 de 1
    • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
  3. Insignia NS-CLOPP2 Screen Replacement: paso 3, imagen 1 de 1
    • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
  4. Insignia NS-CLOPP2 Screen Replacement: paso 4, imagen 1 de 1
    • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
    • To reassemble your device, follow these instructions in reverse order.
Conclusión
2 personas más completaron esta guía.
Dilini De Silva
Miembro Desde 03/11/15
757 Reputación
5 Guías creadas
Equipo
Marist, Team 1-1, Laflen Spring 2015 Miembro de Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 198
