Saltar al contenido principal
Insignia NS-CLOPP2 Motherboard Replacement
Qué necesitas
  1. Insignia NS-CLOPP2 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • First, remove the front screen. (See prerequisite screen removal guide.)
  2. Insignia NS-CLOPP2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
  3. Insignia NS-CLOPP2 Motherboard Replacement: paso 3, imagen 1 de 1
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
  4. Insignia NS-CLOPP2 Motherboard Replacement: paso 4, imagen 1 de 1
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    • To reassemble your device, follow these instructions in reverse order.
Conclusión
3 personas más completaron esta guía.
Dilini De Silva
Miembro Desde 03/11/15
757 Reputación
5 Guías creadas
Equipo
Marist, Team 1-1, Laflen Spring 2015 Miembro de Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 144
