Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. Locate the bottom of the device.
    • Locate the bottom of the device.
  2. Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Locate the 11mm screw beneath the sticker.
    • Locate the 11mm screw beneath the sticker.
  4. Using a plastic spudger, peel off the adhesive gel stoppers.
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Continue peeling the rest of the gel stoppers from the bottom of the device.
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Begin unscrewing the six 11mm screws with a Phillips head screw driver.
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Once you peel of the bottom from the device, you will see the motherboard.
    • Once you peel of the bottom from the device, you will see the motherboard.
  8. Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Lift the motherboard from the device.
    • Lift the motherboard from the device.
  10. Locate the four plugs connecting the motherboard to the rest of the device.
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Begin with remove the plug to your left.
    • Begin with remove the plug to your left.
  12. Remove the plug to your right from the motherboard.
    • Remove the plug to your right from the motherboard.
  13. Remove the plug in the front of the lcd screen plug.
    • Remove the plug in the front of the lcd screen plug.
  14. Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the power auxiliary port.
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the power auxiliary port.
Conclusión
Erik
Miembro Desde 19/02/15
405 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 9-3, Leahy Winter 2015 Miembro de USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 117
