Saltar al contenido principal
Insignia NS-CLIP02 30-Pin Connector Replacement
Qué necesitas
  1. Insignia NS-CLIP02 30-Pin Connector Replacement, 30-Pin Connector: paso 1, imagen 1 de 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 2, imagen 1 de 1
    • Begin by using the Metal Spudger to peel back the adhesive sticker and locate the screw beneath the sticker.
  3. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 3, imagen 1 de 1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 4, imagen 1 de 1
    • Using the Plastic Spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 5, imagen 1 de 1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 6, imagen 1 de 1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 7, imagen 1 de 1
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 8, imagen 1 de 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 9, imagen 1 de 1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 10, imagen 1 de 1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 11, imagen 1 de 1
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 12, imagen 1 de 1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 13, imagen 1 de 1
    • Remove the plug in front of the LCD screen plug.
  14. Insignia NS-CLIP02 30-Pin Connector Replacement: paso 14, imagen 1 de 1
    • Remove the LCD screen plug. Then, follow the previous instructions in reverse, replacing the old motherboard with the new one to fix the 30-Pin Connector.
Conclusión
Erik
Miembro Desde 02/19/15
405 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 9-3, Leahy Winter 2015 Miembro de USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 216
