Saltar al contenido principal
Insignia NS-B2110 Battery Replacement
Qué necesitas
  1. Insignia NS-B2110 Battery Replacement, Battery: paso 1, imagen 1 de 2 Insignia NS-B2110 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: paso 2, imagen 1 de 2 Insignia NS-B2110 Battery Replacement: paso 2, imagen 2 de 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Conclusión
Daniel Hodges
Miembro Desde 10/14/13
301 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-31, Amido Fall 2013 Miembro de Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 359
