Introducción
We are going to show the user how to successfully replace the I/O covers on the Insignia NS-24ER310NA17.
Qué necesitas
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
After following the prerequisite guides, you should have the main board off with the black plastic still on. To remove the plastic, unscrew the nut that holds this plastic to the cable input on the board.
Una persona más ha completado esta guía.
