Introducción
Use this guide to replace the infrared sensor in your Insignia NS-24ER310NA17 television.
Qué necesitas
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Unplug ribbon cable from port on main board that corresponds with IR sensor.
Una persona más ha completado esta guía.
