Introducción
This guide will take you through the process of disassembling the housing of the Insignia NS-24ER310NA17 in order to gain access to the inner parts. This is a primary step for most replacement guides regarding this device.
Qué necesitas
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Casi Terminas!
Conclusión
