Saltar al contenido principal
Insignia NS-15MS0832B Speaker Replacement
Qué necesitas
  1. Insignia NS-15MS0832B Speaker  Replacement, Speakers: paso 1, imagen 1 de 1
    • Begin the speaker replacement by inserting the plastic opening tool into the corner of the device.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Speaker  Replacement: paso 2, imagen 1 de 1
    • Once the backplate is separated from the screen it should look like this.
  3. Insignia NS-15MS0832B Speaker  Replacement: paso 3, imagen 1 de 1
    • Gently set the tablet screen-side down.
    • The speakers can be located at the bottom of the tablet, below the battery.
    • Using a screwdriver, remove the five 1.2 mm Phillips #1 screws that hold the speakers to the tablet.
  4. Insignia NS-15MS0832B Speaker  Replacement: paso 4, imagen 1 de 1
    • Once first speaker has been removed, remove the other speaker opposite from it.
  5. Insignia NS-15MS0832B Speaker  Replacement: paso 5, imagen 1 de 1
    • Once faulty speakers have been unscrewed, disconnect the speaker and attach the new speaker to the mother board.
Conclusión
Harrison Smith
Miembro Desde 10/19/16
329 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 1-1, Bennett Fall 2016 Miembro de Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 244
