Saltar al contenido principal
Insignia NS-15MS0832B Power Button Replacement
Qué necesitas
  1. Insignia NS-15MS0832B Power Button Replacement, Power Button: paso 1, imagen 1 de 1
    • The power button is located on the top side on the tablet, along side the charging port and MicroUSB port
  2. Insignia NS-15MS0832B Power Button Replacement: paso 2, imagen 1 de 1
    • Starting in the corner, carefully insert the plastic opening tool.
    • Work the plastic opening tool carefully around the entire device to pry it open.
  3. Insignia NS-15MS0832B Power Button Replacement: paso 3, imagen 1 de 1
    • Once the tablet is completely open, set aside the back half.
    • Carefully place the other half of the tablet screen-side down.
  4. Insignia NS-15MS0832B Power Button Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, gently grab the power button and pull it out from the tablet.
  5. Insignia NS-15MS0832B Power Button Replacement: paso 5, imagen 1 de 1
    • Once the faulty power button is removed, follow the directions in reverse order to reassemble the device.
Conclusión
Harrison Smith
Miembro Desde 10/19/16
329 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 1-1, Bennett Fall 2016 Miembro de Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
Miembros de 4
6 Guías creadas
2 comentarios
If the power button doesn’t physically click anymore, can you order a replacement? Is it even possible to solder on a new power button?
Thanks in advance…
Chris - Contestar
Can you do this with the volume rocker? My Insignia tablet has a faulty rocker, and I need to fix it. (Note- the “+” part of the volume button sticks and jams the volume to 100 until I press “-”.)
Andy Joonseo Bae - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 1,054
