Saltar al contenido principal
Insignia NS-15MS0832B Battery Replacement
Qué necesitas
  1. Insignia NS-15MS0832B Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Begin the replacement for the battery by opening up the device with a plastic opening tool along the edge.
    • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
  2. Insignia NS-15MS0832B Battery  Replacement: paso 2, imagen 1 de 1
    • Your tablet should look like this once separated.
  3. Insignia NS-15MS0832B Battery  Replacement: paso 3, imagen 1 de 1
    • Start by placing tablet face down and carefully removing the mesh wire tap from the back of the battery.
  4. Insignia NS-15MS0832B Battery  Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the flat wire from its connector with the tweezers and fold to the side so that it's clear of the battery.
  5. Insignia NS-15MS0832B Battery  Replacement: paso 5, imagen 1 de 1
    • Next locate where the battery has three wires attached to the mother board. Take out the soldering iron and begin heating it up.
    • Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
  6. Insignia NS-15MS0832B Battery  Replacement: paso 6, imagen 1 de 1
    • Once the soldering iron has heated up, begin by placing the tip of the iron where the wire directly meets the mother board. The soldering should heat up and allow you to gently pull the wire off. Repeat twice more to remove each of the three wires.
  7. Insignia NS-15MS0832B Battery  Replacement: paso 7, imagen 1 de 1
    • Once all wires have been removed from mother board, take plastic opening tool and separate the battery from the back of the screen. Its connected with glue, so don't worry.
  8. Insignia NS-15MS0832B Battery  Replacement: paso 8, imagen 1 de 1
    • Remove battery and replace faulty one with new battery.
Conclusión
To reassemble your Insignia W-Fi Windows 8" Tablet, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Harrison Smith
Miembro Desde 10/19/16
329 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 1-1, Bennett Fall 2016 Miembro de Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 1,211
