Introducción
If your Insignia Flex Elite 7.85 will not turn on or charge, you need to replace the battery.
Qué necesitas
Use a plastic opening tool to remove the metal backing of the tablet.
Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
Move the tool around the perimeter of the device until the screen separate.
Casi Terminas!
Conclusión
