Saltar al contenido principal
Insignia Flex 8 NS-P16AT08 Battery Replacement
Qué necesitas
  1. Insignia Flex 8 NS-P16AT08 Battery Replacement, Back Casing: paso 1, imagen 1 de 3 Insignia Flex 8 NS-P16AT08 Battery Replacement, Back Casing: paso 1, imagen 2 de 3 Insignia Flex 8 NS-P16AT08 Battery Replacement, Back Casing: paso 1, imagen 3 de 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Battery Replacement: paso 2, imagen 1 de 1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Gently peel the tape that is covering the cable connections going to and from the battery and set tape aside.
    • This will expose the cable connections in preparation for disconnecting the cables and battery.
  4. Insignia Flex 8 NS-P16AT08 Battery Replacement: paso 4, imagen 1 de 2 Insignia Flex 8 NS-P16AT08 Battery Replacement: paso 4, imagen 2 de 2
    • Locate battery cable connection.
    • Pull gently on cable that connects the battery to the motherboard.
    • Cable will stay attached to battery but be removed from motherboard.
    • If pulling gently doesn't loosen cable, wiggle connection while pulling gently.
  5. Insignia Flex 8 NS-P16AT08 Battery Replacement: paso 5, imagen 1 de 1
    • Slide the nylon spudger gently underneath the battery.
    • Using the nylon spudger, gently pry battery from adhesive on metal base.
    • Do not puncture or bend battery.
    • Working around the battery, pry up all the sides to remove the battery from the metal base.
    • The adhesive is very strong. Separating the battery from the metal base may be difficult.
Conclusión
6 personas más completaron esta guía.
5 comentarios
We're do u get a new battery from ???
stephanie maxwell - Contestar
i know this is an old comment but the solution is the same, ebay the model number and you will find many parts for cheap! good luck!
mathew -
i replaced the battery for a customer and now the tablet is stuck at boot hmmm.....
mathew - Contestar
after about 3 minutes the device booted apparently I am just too impatient, still another happy customer, thanks!
mathew -
Pls help me to  send me the phone number of the above mentioned Mattew or give him my phone number. I will discuss with him  to replace my charger plug and possibly the battery. thanks.
tesfay gmichael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 3,282
