Saltar al contenido principal
Insignia Flex 8 NS-P16AT08 Back Casing Replacement
Qué necesitas
  1. Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: paso 1, imagen 1 de 3 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: paso 1, imagen 2 de 3 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: paso 1, imagen 3 de 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Back Casing Replacement: paso 2, imagen 1 de 1
    • Lift the back casing away from the screen.
    • Set casing aside.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 601
