Saltar al contenido principal
Insignia Flex 8 NS-P08A7100 Battery Replacement
Qué necesitas
  1. Insignia Flex 8 NS-P08A7100 Battery Replacement, Battery: paso 1, imagen 1 de 2 Insignia Flex 8 NS-P08A7100 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Begin by using the opening tool to pry open the back cover. Continue around the edge until the back cover pops off.
  2. Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 2, imagen 1 de 2 Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 2, imagen 2 de 2
    • Use the opening tool to flip the LCD flex circuit plug upwards. The flex circuit should now be loose. Remove flex circuit by pulling outwards.
  3. Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 3, imagen 1 de 2 Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 3, imagen 2 de 2
    • Use the opening tool to remove the battery cable from the circuit board.
  4. Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the adhesive tape from the bottom of the battery.
  5. Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 5, imagen 1 de 1
    • Remove plastic adhesive tape from the side of the battery.
  6. Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 6, imagen 1 de 2 Insignia Flex 8 NS-P08A7100 Battery Replacement: paso 6, imagen 2 de 2
    • Pry the battery from the back of the LCD screen using the opening tool. Due to the strong adhesive between the battery and screen, this may take some time.
Conclusión
Lavina Pillai
Miembro Desde 07/08/19
133 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G1, Renguette Summer 2019 Miembro de IUPUI, Team S1-G1, Renguette Summer 2019
IUPUI-RENGUETTE-SU19S1G1
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 236
