Saltar al contenido principal
Insignia Flex 8 NS-15AT08 Battery Replacement
Qué necesitas
  1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: paso 1, imagen 1 de 2 Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Battery Replacement: paso 2, imagen 1 de 2 Insignia Flex 8 NS-15AT08 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: paso 3, imagen 1 de 2 Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
  4. Insignia Flex 8 NS-15AT08 Battery Replacement: paso 4, imagen 1 de 3 Insignia Flex 8 NS-15AT08 Battery Replacement: paso 4, imagen 2 de 3 Insignia Flex 8 NS-15AT08 Battery Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
  5. Insignia Flex 8 NS-15AT08 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
Conclusión
4 personas más completaron esta guía.
Jeremy Anaya
Miembro Desde 09/23/15
316 Reputación
2 Guías creadas
Equipo
Baylor, Team 6-7, Williams Fall 2015 Miembro de Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,918
