Saltar al contenido principal
Insignia Flex 8 NS-15AT08 Back Casing Replacement
Qué necesitas
  1. Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: paso 1, imagen 1 de 2 Insignia Flex 8 NS-15AT08 Back Casing Replacement, Back Casing: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Back Casing Replacement: paso 2, imagen 1 de 2 Insignia Flex 8 NS-15AT08 Back Casing Replacement: paso 2, imagen 2 de 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
Conclusión
Krystal Rhodes
Miembro Desde 09/22/15
488 Reputación
3 Guías creadas
Equipo
Baylor, Team 6-7, Williams Fall 2015 Miembro de Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 477
