Saltar al contenido principal
Insignia Flex 7 Battery Replacement
Qué necesitas
  1. Insignia Flex 7 Battery Replacement, Battery: paso 1, imagen 1 de 3 Insignia Flex 7 Battery Replacement, Battery: paso 1, imagen 2 de 3 Insignia Flex 7 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Battery Replacement: paso 2, imagen 1 de 2 Insignia Flex 7 Battery Replacement: paso 2, imagen 2 de 2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Battery Replacement: paso 3, imagen 1 de 3 Insignia Flex 7 Battery Replacement: paso 3, imagen 2 de 3 Insignia Flex 7 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Link for replacement battery?
Mike - Contestar
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 972
