Saltar al contenido principal
Insignia Flex 10.1 NS-P10W8100 Camera Replacement
Qué necesitas
  1. Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: paso 1, imagen 1 de 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 2, imagen 1 de 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 2, imagen 2 de 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 3, imagen 1 de 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 4, imagen 1 de 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 4, imagen 2 de 2
    • Carefully remove the yellow tape holding down the camera ribbon connector by pulling it upwards.
    • Remove the black tape holding down the camera ribbon connector which is attached to the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 5, imagen 1 de 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 5, imagen 2 de 2
    • Disconnect the zero insertion force (ZIF) connector by using your fingernail to flip the small locking flap.
    • Disconnect the cable by gently pulling it outward.
  6. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 6, imagen 1 de 3 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 6, imagen 2 de 3 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: paso 6, imagen 3 de 3
    • Remove the camera by pulling it upward.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 7
Todo El Tiempo: 245
