Saltar al contenido principal
Insignia Flex 10.1 NS-P10A7100 Battery Replacement
Qué necesitas
  1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: paso 1, imagen 1 de 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: paso 1, imagen 2 de 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Use the blue iFixit opening tool to remove the backing of the device.
    • Wedge the tool in the crease between the device backing and screen.
  2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 2, imagen 1 de 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 2, imagen 2 de 2
    • Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
    • Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
  3. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 3, imagen 1 de 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 3, imagen 2 de 2
    • Detach the five colored wires that connect the battery to the motherboard.
    • Use two fingers and place one on either side of the white plastic encasing the wires.
    • Pull on this piece to release it from the motherboard.
    • Now the battery is detached from the motherboard.
  4. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 4, imagen 1 de 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 4, imagen 2 de 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: paso 4, imagen 3 de 3
    • The battery is now only connected to the device by the glue on the bottom.
    • Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
    • Now that your battery is removed it is ready for replacement.
Conclusión
Hannah
Miembro Desde 02/05/19
289 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,060
