Saltar al contenido principal
Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement
  1. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement, Rubber Gasket: paso 1, imagen 1 de 1
    • Remove lid and place upside down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: paso 2, imagen 1 de 2 Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: paso 2, imagen 2 de 2
    • Grab the edge of the clear rubber gasket and slowly peel it off the lid.
    • Continue peeling off the gasket until it is completely detached from the lid.
Conclusión
Savannah Webb
Miembro Desde 01/18/18
657 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S12-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Miembros
5 Guías creadas
3 comentarios
Am having trouble Turning the lid from Unlock to lock. The pin comes out in the back when I go to turn it from unlock to lock. Can you help me?
pclarkrob3 - Contestar
I bought the insignia pressure cooker at a garage sale but, the rubber gasket smells bad. I’ve cleaned the entire cooker but, that gasket stinks like no other
Chuck Smith - Contestar
I am having the same problem as the first comment by pclarkrob3 I am having trouble turning the lid from unlock to lock. These are really crappy instructions!!!! I have only used my pressure cooker twice so everything is still new.
Vivian Lang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,234
