Saltar al contenido principal
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: paso 1, imagen 1 de 1
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: paso 2, imagen 1 de 1
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: paso 3, imagen 1 de 2 Insignia 6-Quart Pressure Cooker Float Valve Replacement: paso 3, imagen 2 de 2
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
Conclusión
3 personas más completaron esta guía.
Savannah Webb
Miembro Desde 01/18/18
657 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S12-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Miembros
5 Guías creadas
2 comentarios
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - Contestar
OK after much digging, I found the old valve and now it is pressurizing.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 75
Todo El Tiempo: 4,364
