Saltar al contenido principal
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
Qué necesitas
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: paso 1, imagen 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 2, imagen 1 de 1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 3, imagen 1 de 1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 4, imagen 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 5, imagen 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 6, imagen 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 7, imagen 1 de 1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 8, imagen 1 de 1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 9, imagen 1 de 1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 10, imagen 1 de 1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 11, imagen 1 de 1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 12, imagen 1 de 1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 13, imagen 1 de 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: paso 14, imagen 1 de 1
    • Remove and replace the circuit board.
Conclusión
5 personas más completaron esta guía.
Savannah Webb
Miembro Desde 01/18/18
657 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S12-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Miembros
5 Guías creadas
8 comentarios
Where do you purchase the circuit board
Douglas Koons - Contestar
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - Contestar
Please, Where can I buy the electrical circuit?
Mohammed - Contestar
why is my circuit board not fixed to the top like in the diagram
david stanley - Contestar
where can I purchase the circuit board
de27@bellsouth.net - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 3,212
