Saltar al contenido principal
Introducción
You'll probably never need to diagnose an instrument light problem with your car, but that doesn't mean you can't have fun performing this test. And knowing that the gauges and lights are working is reassuring.
If you want to show this to friends, be warned that HID headlights service life can be reduced by turning them on and off needlessly. The bulbs aren't cheap.
Herramientas
No se especificaron herramientas.
Partes
  1. This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure.  As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
  2. Insert the ignition key into the ignition lock. Leave it in the 0 or I position. Push and hold the Sel/Reset  knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display  Info button. Push and hold the Sel/Reset  knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display  Info button.
    • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
    • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
  3. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  4. Turn the headlights ON.
    • Turn the headlights ON.
  5. Turn the ignition switch to ON (position II). Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
    • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
  6. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
    • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
  7. Within 5 seconds, release the Sel/reset button. Push and release the Sel/reset button button 3 times repeatedly. The instrument cluster begins its self-test.
    • Within 5 seconds, release the Sel/reset button.
    • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
    • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
    • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
    • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
Linea de Meta
7 personas más completaron esta guía.
David Spalding
Miembro Desde 12/11/15
5,320 Reputación
9 Guías creadas
This looks like the fix I may be looking for! What make or model vehicle is this? My Chrysler Town & Country used to occasionally get the gauge needles pinned to infinite and there was a similar procedure to run the self test and reset the needles. My Mom’s old GM Delta 88 has been having a similar problem and I am wondering if this procedure will work on her car.
George Hickey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 62
Últimos 7 Días: 718
Últimos 30 Días: 5,270
Todo El Tiempo: 118,144
