Saltar al contenido principal
Infant Optics DXR-8 Speaker Replacement
Qué necesitas
  1. Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: paso 1, imagen 1 de 3 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: paso 1, imagen 2 de 3 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: paso 1, imagen 3 de 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Speaker Replacement: paso 2, imagen 1 de 3 Infant Optics DXR-8 Speaker Replacement: paso 2, imagen 2 de 3 Infant Optics DXR-8 Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Speaker Replacement: paso 3, imagen 1 de 3 Infant Optics DXR-8 Speaker Replacement: paso 3, imagen 2 de 3 Infant Optics DXR-8 Speaker Replacement: paso 3, imagen 3 de 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
  5. Infant Optics DXR-8 Speaker Replacement: paso 5, imagen 1 de 1
    • Lift the speaker from casing using metal spudger.
    • Place new 8W speaker in the casing and connect wire.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 6-4, Remmell Fall 2015 Miembro de USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 Miembros
3 Guías creadas
5 comentarios
Where to purchase the replacement speaker?
Keiundra Joiner - Contestar
Where can we purchase the replacement 8w speaker part
lea placek - Contestar
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - Contestar
Thanks for this. Found something on Ali Express, just need to figure out the right size
https://www.aliexpress.us/item/325680361...
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 81
Todo El Tiempo: 16,963
