Saltar al contenido principal
Infant Optics DXR-8 Power Button Replacement
Qué necesitas
  1. Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: paso 1, imagen 1 de 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: paso 1, imagen 2 de 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: paso 1, imagen 3 de 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Power Button Replacement: paso 2, imagen 1 de 3 Infant Optics DXR-8 Power Button Replacement: paso 2, imagen 2 de 3 Infant Optics DXR-8 Power Button Replacement: paso 2, imagen 3 de 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Power Button Replacement: paso 3, imagen 1 de 3 Infant Optics DXR-8 Power Button Replacement: paso 3, imagen 2 de 3 Infant Optics DXR-8 Power Button Replacement: paso 3, imagen 3 de 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Power Button Replacement, Power Button: paso 4, imagen 1 de 1
    • The power button is located at the top of the device.
  5. Infant Optics DXR-8 Power Button Replacement: paso 5, imagen 1 de 1
    • Remove the button by picking it up out of the hole it is connected to.
  6. Infant Optics DXR-8 Power Button Replacement: paso 6, imagen 1 de 1
    • Insert a new button by placing the small end in the hole to connect the button to the device.
Conclusión
To reassemble your device, follow the instructions in reverse order.
2 personas más completaron esta guía.
2 comentarios
Where did you get the replacement switch?
Dave Peterson - Contestar
Where can you purchase a new power switch on the circuit board for replacement?
Derrick Silvestri - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 4,894
