Saltar al contenido principal
Infant Optics DXR-8 Monitor Motherboard Replacement
Qué necesitas
  1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: paso 1, imagen 1 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: paso 1, imagen 2 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: paso 1, imagen 3 de 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Motherboard Replacement: paso 2, imagen 1 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 2, imagen 2 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Motherboard Replacement: paso 3, imagen 1 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 3, imagen 2 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 3, imagen 3 de 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: paso 4, imagen 1 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: paso 4, imagen 2 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: paso 4, imagen 3 de 3
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Motherboard Replacement: paso 5, imagen 1 de 2 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Motherboard Replacement: paso 6, imagen 1 de 1
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Motherboard Replacement: paso 7, imagen 1 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 7, imagen 2 de 3 Infant Optics DXR-8 Monitor Motherboard Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
  8. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: paso 8, imagen 1 de 2 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: paso 8, imagen 2 de 2
    • Flip the motherboard away from the case.
    • Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
Can you do one for the DXR-8 Pro monitor? Mine randomly stoped turning on and I want to see if I can open it up and try to fix it.
Andfel - Contestar
Can you please tell me where to buy a replacement motherboard??
Ilya Nechay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 1,078
