Introducción
If the monitor of the Infant Optics DXR-8 is not functioning properly, the motherboard may be faulty. Follow these instructions to replace the motherboard in the monitor.
Qué necesitas
Using the plastic opening tool, remove screen protector from front of monitor.
Using a plastic opening tool, disconnect the ribbon cable connector.
Gently separate the ribbon cable from the motherboard.
Flip the motherboard away from the case.
Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
Una persona más ha completado esta guía.
2 comentarios
Can you please tell me where to buy a replacement motherboard??
