Saltar al contenido principal
Infant Optics DXR-8 Charging Port Replacement
Qué necesitas
  1. Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: paso 1, imagen 1 de 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: paso 1, imagen 2 de 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: paso 1, imagen 3 de 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Charging Port Replacement: paso 2, imagen 1 de 3 Infant Optics DXR-8 Charging Port Replacement: paso 2, imagen 2 de 3 Infant Optics DXR-8 Charging Port Replacement: paso 2, imagen 3 de 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Charging Port Replacement: paso 3, imagen 1 de 3 Infant Optics DXR-8 Charging Port Replacement: paso 3, imagen 2 de 3 Infant Optics DXR-8 Charging Port Replacement: paso 3, imagen 3 de 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Charging Port Replacement, Charging Port: paso 4, imagen 1 de 2 Infant Optics DXR-8 Charging Port Replacement, Charging Port: paso 4, imagen 2 de 2
    • Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
  5. Infant Optics DXR-8 Charging Port Replacement: paso 5, imagen 1 de 2 Infant Optics DXR-8 Charging Port Replacement: paso 5, imagen 2 de 2
  6. Infant Optics DXR-8 Charging Port Replacement: paso 6, imagen 1 de 1
    • Remove the old charging port and solder the new one in place.
  7. Infant Optics DXR-8 Charging Port Replacement: paso 7, imagen 1 de 1
    • Flip the unit over to ensure a correct fitment.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 13-4, Banghart Winter 2017 Miembro de Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Miembros
4 Guías creadas
3 comentarios
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - Contestar
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
Donovan Zusalim -
Worth pointing out that this guide shows an older version of the DXR-8 (2014 printed on the PCB) where the microUSB port uses through-hole leads to connect to the board. Mine is a few years newer and the port was surface-mounted, which requires more skill and care to replace. I ended up ordering the part myself and taking it to a repair shop for them to do the soldering.
Danny Conrad - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 46
Todo El Tiempo: 6,219
