Saltar al contenido principal
Infant Optics DXR-8 Camera Speaker Replacement
Qué necesitas
  1. Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: paso 1, imagen 1 de 2 Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: paso 1, imagen 2 de 2
    • Position the camera with bottom facing toward you.
    • Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
  2. Infant Optics DXR-8 Camera Speaker Replacement: paso 2, imagen 1 de 2 Infant Optics DXR-8 Camera Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
  3. Infant Optics DXR-8 Camera Speaker Replacement: paso 3, imagen 1 de 1
    • Open the bottom of the camera to reveal the circuit board and speaker.
  4. Infant Optics DXR-8 Camera Speaker Replacement, Camera Speaker: paso 4, imagen 1 de 1
    • Disconnect the speaker cable from the circuit board for ease of access.
  5. Infant Optics DXR-8 Camera Speaker Replacement: paso 5, imagen 1 de 1
    • Lift the speaker from the casing using a metal spudger.
    • Place a new 8W speaker in the casing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 13
Ultimos 30 días: 25
Todo El Tiempo: 2,183
