Saltar al contenido principal
Infant Optics DXR-8 Back Cover Prerequisite
Qué necesitas
  1. Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: paso 1, imagen 1 de 3 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: paso 1, imagen 2 de 3 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: paso 1, imagen 3 de 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Back Cover Prerequisite: paso 2, imagen 1 de 3 Infant Optics DXR-8 Back Cover Prerequisite: paso 2, imagen 2 de 3 Infant Optics DXR-8 Back Cover Prerequisite: paso 2, imagen 3 de 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Back Cover Prerequisite: paso 3, imagen 1 de 3 Infant Optics DXR-8 Back Cover Prerequisite: paso 3, imagen 2 de 3 Infant Optics DXR-8 Back Cover Prerequisite: paso 3, imagen 3 de 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
Conclusión
20 personas más completaron esta guía.
Peyton Ulrich
Miembro Desde 01/24/17
515 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-4, Banghart Winter 2017 Miembro de Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Miembros
4 Guías creadas
27 comentarios
Great walkthrough. One suggestion i have is to make sure to remove the battery before doing any of the disassembly. Great guide!
Derrick Brown - Contestar
Any idea where I could buy a replacement screen though? I just dropped mine and the screen is broken. The front plastic is still undamaged.
Jon Woolery - Contestar
I bought a Sharp LQ035NC111 LCD Display eBay for $8.46 and it did the trick
Nathaniel Wolf -
Do you know where I could buy a replacement screen for this device? I just dropped mine and the only damage that I can see is a crack in the LCD that is making the image almost entirely unviewable.
I replaced mine with a “3.5" Inch QVGA 240x320 TFT Color LCD Display Module LQ035NC111 54pin” I found on ebay for $8.81, works great.
Just Being Helpful -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 36
Ultimos 30 días: 138
Todo El Tiempo: 29,734
