Saltar al contenido principal
Infant Optics DXR-5 Monitor Screen Replacement
Qué necesitas
  1. Infant Optics DXR-5 Monitor Screen Replacement, Battery: paso 1, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Press on the blue clip on the back and slide it down.
    • In the second picture there is a slight gap at the top of the blue clip.
  2. Infant Optics DXR-5 Monitor Screen Replacement: paso 2, imagen 1 de 1
    • Pull the blue clip away from the body of the hand held monitor.
  3. Infant Optics DXR-5 Monitor Screen Replacement: paso 3, imagen 1 de 1
    • Slide the rear white panel off as shown.
  4. Infant Optics DXR-5 Monitor Screen Replacement: paso 4, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement: paso 4, imagen 2 de 2
    • Remove the battery by pushing in on the right side and then pulling the battery up and out of the body of the hand held monitor.
  5. Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: paso 5, imagen 1 de 3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: paso 5, imagen 2 de 3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: paso 5, imagen 3 de 3
    • Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
    • There are two types of screws. Be sure to return the screws to their respective holes upon reassembly.
  6. Infant Optics DXR-5 Monitor Screen Replacement: paso 6, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement: paso 6, imagen 2 de 2
    • Carefully remove the clear face plate on the front of the hand held monitor using a plastic spudger and a suction cup.
    • Use a heat source to loosen the adhesive around the edge of the face plate before applying any pressure to the face plate.
  7. Infant Optics DXR-5 Monitor Screen Replacement: paso 7, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement: paso 7, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that are exposed after removing the face plate.
  8. Infant Optics DXR-5 Monitor Screen Replacement: paso 8, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement: paso 8, imagen 2 de 2
    • Using a drill carefully drill out the plastic posts that connect the mother board to the face plate.
  9. Infant Optics DXR-5 Monitor Screen Replacement: paso 9, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement: paso 9, imagen 2 de 2
    • Carefully open the hand held monitor and flip the screen (highlighted in red) out of the way.
  10. Infant Optics DXR-5 Monitor Screen Replacement: paso 10, imagen 1 de 2 Infant Optics DXR-5 Monitor Screen Replacement: paso 10, imagen 2 de 2
    • Remove the hand held monitor screen from the mother board by carefully pulling from the point where it is attached with an adhesive to the mother board.
Conclusión
Una persona más ha completado esta guía.
Charles Neal
Miembro Desde 08/31/15
687 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 6-2, Remmell Fall 2015 Miembro de USF Tampa, Team 6-2, Remmell Fall 2015
USFT-REMMELL-F15S6G2
5 Miembros
5 Guías creadas
Un comentario
Any ideas on where to source the replacement screen?
Abdullah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,928
