Saltar al contenido principal
Infant Optics DXR-5 Camera Lens Replacement
Qué necesitas
  1. Infant Optics DXR-5 Camera Lens Replacement, Camera: paso 1, imagen 1 de 2 Infant Optics DXR-5 Camera Lens Replacement, Camera: paso 1, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the four, 6.0 mm Phillips screws from the back of the camera unit.
  2. Infant Optics DXR-5 Camera Lens Replacement: paso 2, imagen 1 de 2 Infant Optics DXR-5 Camera Lens Replacement: paso 2, imagen 2 de 2
    • Pull up on the two beige tabs to the left and right of the ribbon connected to the camera.
    • Pull the ribbon straight out from the camera.
  3. Infant Optics DXR-5 Camera Lens Replacement: paso 3, imagen 1 de 2 Infant Optics DXR-5 Camera Lens Replacement: paso 3, imagen 2 de 2
    • Remove the front face plate of the camera unit by carefully pulling it off.
  4. Infant Optics DXR-5 Camera Lens Replacement, Camera Lens: paso 4, imagen 1 de 2 Infant Optics DXR-5 Camera Lens Replacement, Camera Lens: paso 4, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that hold the camera lens on.
    • These two screws have a different thread than the four screws that secure the camera unit's housing.
Conclusión
Charles Neal
Miembro Desde 08/31/15
687 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 6-2, Remmell Fall 2015 Miembro de USF Tampa, Team 6-2, Remmell Fall 2015
USFT-REMMELL-F15S6G2
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 573
